OKI ES3640e / C9800 prints blank pages between a run of x-copies
  • Jeroen
    • Aug 2025
    I have a problem with a OKI ES3640e.
    When i send a single-sheet printjob of 100 sheets, i will get 100 sheets out of the printer. (there are no double paper feeds in this job) But a few (mostly between 1 and 10) are blank.
    Does anyone know a solution or cause for this malfunction?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • Jeroen
      Thank you for your answer but which parts and/or service manual do you mean?
      Not that i mentioned it, but i already have the manuals provided by Oki.
      TIA, Jeroen
      • JustManuals
        • Jan 2006
        • 9838
        I have them both.
        • Print Doc
          does this happen when you print from any application?
          • Jeroen
            I dont know if it happens from any app. But it seems te be the PS driver that have this effect. With PCL afaik it doesn't.
            Apps that have this issue are: adobe reader, adobe acrobat, adobe indesign, msWord, Pagemaker, Publisher, OO and others. So, it seems like it would be from any app.
            • Print Doc
              Try to un install the driver from server properties and download new driver
              • Eric1968
                • 2458
                Check the drumcartridge contacts. Maybe they're somewhat bent.
