oki 4520
  • Iman
    • Jul 2008
    • 57
    oki 4520
    Hi all I have posted this thread under its utax model number but I found out that its also an oki 4520.
    Has anybody seen a problem on the OKI 4520 fax. When the fax is printing a recieved fax it may print one or two pages and then ask for A4 paper to be inserted in the upper tray. Even if paper is added to the upper tray the fax still will not print. If the fax is rebooted it may print one or two pages and then display the same message -insert A4 paper in the upper tray. There was a mod issiued regarding this problem which I fitted but still the problem occurs. Any info would be much appreciated.
    Thanks.
