The printer/copier/fax I use is hooked up to a network system. I work on documents using Microsoft Visio and for the past few days whenever I go to print a document the entire file is shifted to the left when it prints. This has also occured when it is turned into a pdf file and printed. Other peers have had the same problem printing through Visio. Microsoft word and other programs appear to print out centered and are alright. Also, when the visio file is sent to print on a different printer it is centered. What is going on with the printer and what needs to be done to fix this? It looks like a printer issue and not a program issue.
