Decisions decisions! Oki CX2032 or Oki C5510?
  • waite747
    • Jun 2025
    I am looking into buying a copier/mulit-functional printer. I have two options a, Oki CX2032 for $600 or an OKI C5510 for $200. Which is a better deal? Is there a major difference between the two? Is there any reason I should go with the more expensive one? Help me please!
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    Re: Decisions decisions! Oki CX2032 or Oki C5510?
    We have an OKI CX2633 and an OKI CX3641MFP in the field. The CX2633 has performed flawlessly in a moderate multifunctional environment. The CX3641 is in a high user, high security, constantly used multi-tasking environment and it has FAILED! Currently, it is being looked at by OKI Japan with no solution 1 year later. Basically print/fax/scan jobs in the queue on the machine would just disappear. But let's just say 2 hard drives, 2 print engines, 3 scanners, MULTIPLE boards, and an OKI rep on-site and the only solution is permently remove the fax board and use a separate fax! Beware OKI. Not to mention, the HDD on this same machine gets corrupt at least once a year and has to be re-written. BEWARE OKI!
    It does not matter how slowly you go as long as you do not stop. –Confucius
