Fujitsu 5110 scanner message
  • Mdkoh
    • Jun 2007
    • 29
    Have the above product and a message has appeared saying to replace the sep pad. Sep pad has been replaced but the message does not go away. Anyone know the procedure for resetting this message? Have had little luck finding any refrence material on this unit. Owners guide is no help either. Thanks in advance.
    Mike
  • Mdkoh
    • Jun 2007
    • 29
    Re: Fujitsu 5110 scanner message
    I did find a resolution to my problem. In the users guide, in section 5, it walks through replacing the consumables and resetting the counters which are contained in the print driver. The message is not shown on the scanner display, they appear on the PC screen as a warning. They apparently do not hinder scanner function at all. I am attaching a pdf of the section this is located in. Hope others find this useful.CONSUMALE REPLACEMENT GUIDE WARNING RESET.pdf
