Standing in front of the machine go around to the right side in the rear on the inside of the leg and you should see either the IF cable sticking out the hole or it may be stuffed up inside. Keep in mind this does you KIP software and if the customer did not get the PC with it good luck on finding parts. You can also try: keepitprinting.com which is a Kip forum. I have worked on several of them but it has been a while. I'm not even sure if it will interface beyond XP. I have manuals, parts, etc if I can be of any help
