Oki es3640E blanc paper
  • Blommers
    • Aug 2025
    [Misc] Oki es3640E blanc paper
    after a paper jam, removed paper I have only blanc copies, no error code or so in display,
    seems to function normal, but the papers are all blanc, no image on it.
    Who nows?
  • Eric1968
    • 2458
    Re: Oki es3640E blanc paper
    Check if the covers of the LED-Heads are moving away when you close the main cover. When the customer is closing the main cover to hard two gears of this mechanism break. This causes the LED-Head covers to keep covering the LED-heads when you close the main cover, which will result blanc pages. Also make sure the LED-Heads make a good ground contact.
    Succes en groeten uit Rotterdam!
    • Blommers
      BEDANKT VOOR DE TIP!
      ga er morgen mee aan de slag.
