Afico 2045 with sc.450
  • bob marley
    • Jan 2012
    • 1339
    Hi everyone
    I have a problem with sc.450 in afico 2045 . there is no overload in the development unit or gears on the drive section and it may be the main motor is defective . can you explain how to test that motor without using in an other machine.
    Best regards
    Live for yourself and you will live in vain. Live for others, and you will live again
  • sandmanmac
    • 3981
    Re: Afico 2045 with sc.450
    Developer motor is shot- not main motor
    • bob marley
      • Jan 2012
      • 1339
      Thanks 4 u . but the machine is Afico 2045 in which there is no developer motor . the development unit is moving only by gears
      • sandmanmac
        • 3981
        ...And what makes those gears turn?....A motor
        See below:
        2035 -PM.pdf
        2035 -SC450.pdf
        • vargue
          • Oct 2011
          • 404
          main motor is leader of operating movment. developing unit move via clutch conjucted with main motor if main motor is weak sc550 released . in big machine there is devlopment motor complete motor .550/650/2090/ alot of gears spin by clutch which all working in same time. some times gears fret. detect that gears which make devloping unit rolling is it rolling or not.
          • bob marley
            • Jan 2012
            • 1339
            See below:
            [ATTACH]14008[/ATTACH]
            [ATTACH]14009[/ATTACH]
            u r right .... no doubt that a motor makes the development gears turns . and that is the feed /dev. motor which I realized it has two different functions in Afico 2035 / 2045 and in other similar machines . That means there is difference between machine code : ( B135 / B138 ) which has no development clutch in the {development drive unit } and (B003.../B007). But is it possible to test the motor without being used in another machine ?
            • sandmanmac
              • 3981
              SP mode 5-804-32 will turn on Feed /development motor
