oki c5950 need firmware for recovery menu network
  • whtie_ghost
    • Aug 2025
    Hi all.
    After reset drum unit, my printer have lost menu network.
    I tried files upload in printer
    PJL_734_NIC005_p0406_w0405.bin
    and
    PJL_p0801_w0801_cA201_aA201.bin
    no worked. Printer say first "Data Archive" after "FAILED-WRITE"
    Please help any more.
    may by someone fixed this problem with OKI C5950. Please share instructions and necessary files
  • JustManuals
    • Jan 2006
    • 9838
    Re: oki c5950 need firmware for recovery menu network
    Need Need Need. What are you offering in return?
    • Eric1968
      • 2458
      I think you have a problem with the network interface. Firmware won't resolve this. When the Network Interface is not working the Network Menu disappears.
      • FalconFour
        • Aug 2011
        • 9
        I have a C6050 with corrupt NIC firmware, very similar situation - I ran a "flash format" thinking that it would only reset to defaults, but actually wiped the NIC firmware. I have HostIF.exe but I have the BIN file referenced in the first post - a common "leak" found on fixyourownprinter.com. The printer, perhaps rightly, doesn't accept the file.
        I don't know what would be a good offer other than not being a know-nothing noob, and can generally handle technical things. Problem here is firmware files locked behind closed doors of the internet - thanks, Oki. If money talks, does $20 offered though a Square $CashTag or PayPal speak loud enough?
