Oki mc361 613 code
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Oki mc361 613 code
    Machine says toner ctg not installed.....when installing a new oem black toner ctg. Nothing broken and shutter opening properly. Any ideas? Did a web search and it seems to be a common problem.no fixes were posted however. Machine is only 2 months old and has almost no mileage.
  • Eric1968
    • 2458
    Re: Oki mc361 613 code
    There are a problems with the drum unit. I've seen similar problems on the MC561 and the C530. Replace the drum unit. You can file a warranty claim, and Oki will supply you a new drum unit.
    • blazebusiness
      • 1250
      My hunch was the drum unit also. Thanks for replying. Shooting you some rep power for taking the time -
      • cluckau
        I have the same problem, The new drum with primer cartridges does the same thing. Oki sent a replacement printer. Still have the same issue. Both drums work in my MC561 fine but will not work correctly in either of the 361's????
        • JustManuals
          • Jan 2006
          • 9838
          I have the maintenance manual on my site at http://www.justmanuals.com
          Paul
          • cluckau
            I just found out that the 361 is compatible only standard cartridges not high, if you install 5k cartridges it will show Not Installed. Hope that helps.
            • skyhawk
              Seriously? Is there a fix or firmware update to address this? Or is this intentional crippling of the printer by the manufacturer?
              The part fits perfectly, even matches the keying, and it seems the MC361 and MC561 use identical print engines....
