OCE 3165, What are the most common "need replaced " parts.
  • Doug James
    • Jan 2012
    • 934
    My customer has this machine and it has been running GREAT. Getting redy to order parts for the contract and need to know what to order. Appreciate ya'lls help...
  • asirir
    • May 2009
    • 7
    Re: OCE 3165, What are the most common "need replaced " parts.
    If it is work fine, no need to replace any parts. Cleaning roller for nearly 0.6 million copies, master belt 2.5 - 3 million. One place I know, they go 4 million on master belt. Now there copy counter is 16 million.
    • Doug James
      • Jan 2012
      • 934
      How about the "Coolant". Is their anything I can use as a substitute. (Such as plain water). Thanks soooo much for your help...
      • KMOCEtech
        • Feb 2013
        • 6
        You can use water, as H2o is listed on the bottle, but order some coolant, Also TTF belt, OPC, Clean sheets, TTF spiral cleaners, Pin array (charge unit ).
        • Doug James
          • Jan 2012
          • 934
          Thanks so much for your feedback, This really helps !
          • vishop
            • Jan 2011
            • 220
            Separation roller for DADF
            DADF exit rollers
            quality package
            TTF belt
            conveyor velt
            TTF Belt cleaner
            clean sheet
            Master or the OPC
