oce C650 Firmware
  • bartrick
    • Sep 2011
    • 11
    oce C650 Firmware
    can i use the same firmware that a konica minolta c6500 use's . Have one with c-4501 codes and would like to reflash firmware but do not want to kill board. Any and all help would be greatly accepted.
  • kronical
    Kronic Copier Ninja
    • Nov 2009
    • 230
    Re: oce C650 Firmware
    The Oce CS650 will indeed take KM C6500 firmware
    The CS550 will take C5500
    The CS655 will take C5501
    The CS665 will take C6501.
    Before updating, run Output Test 32-0 to test Yellow laser unit. You may have a bad laser unit or a bad PRCB. If you are replacing the laser make sure to set the adjustment values listed on the label of the new laser unit.
