Oce tds 600 doesn't print solid
  • jzheld
    • Sep 2010
    • 162
    [Misc] Oce tds 600 doesn't print solid
    If anybody could help would be great, tds 600 will print with lines, it used to be very bad, much better after developer change and corona wire cleaning, but not prefect, anything you can suggest?
    Thank you. John
  • Robert Dugourd
    CEO DIGITAL ONLY INC
    • Sep 2011
    • 14
    Re: Oce tds 600 doesn't print solid
    Control the bias.
    Did you adjust the density with the laptop and cable?
    • jzheld
      • Sep 2010
      • 162
      I have a rip, density helps but not much.
      Originally posted by Robert Dugourd
      Control the bias.
      • mindhunter
        • May 2008
        • 152
        Thank you. John
        horizental lines or vertical ones?
        • Robert Dugourd
          • Sep 2011
          • 14
          Hi.
          Several options:
          1/Humidity in the room or in the paper.
          We had that in the pass in one of our print shop using the 600 as a back up, this engine cook the toner by radiation, the humidity of the paper does not permit to the toner to fuse or to be transferred onto the paper. Classic.. change the media, try velum for example, try an other roll coming from box.
          2/Change the transfer wires, maybe they are oxidized, If the copy is washed, maybe no transfer charge, the toner goes on the paper by contact, it's not pushed by the transfer to the drum.
          3/Transfer is too low, punch it.
          4/Main charge is just too high, grid contaminated.
          5/Bad drum ground.(contact grease)
          6/Toner too old.
          8/Developer even new, can be defect from factory,
          • lago
            • Oct 2012
            • 13
            Horizontal? do they run to paper edge? if horizontal check ur corona charge assy there is a lip/tab that slides in the housing, on lf and rt side, at times when changing wires it gets bend damage and it will not got right in to guide
            Check the the grid just under charge wire at times when cleaning they get strech out and when engine is copying the vibration will short out with Drum/opc and cause horizontal lines at times 2" inch wide + - Intermitently good luck
            Lago
            • leo
              • Jun 2008
              • 64
              REMEMBER to clean the printhead
              if not the image will beacome weak
              • jzheld
                • Sep 2010
                • 162
                Lol print head are you serious?
                • jzheld
                  • Sep 2010
                  • 162
                  is was vertical lines,, the developer drum was bad. Printing perfect now.
                  • leo
                    • Jun 2008
                    • 64
                    Nope! Not in that answer!
                    Too simple
                    • jzheld
                      • Sep 2010
                      • 162
                      Too simple
                      To simple,
                      ok, will remember that when you will need help.
                      • leo
                        • Jun 2008
                        • 64
                        [QUOTE=jzheld;38567impleok, will remember that when you will need help.[/QUOTE]
                        Sorry, i think you misunderstand
                        I have worked with this plotters since the day they was launched
                        Phd will get dirty and result in light image overall
                        But not lines out.
                        For me its 1 of the first thing i do at every visit
                        • jzheld
                          • Sep 2010
                          • 162
                          But not lines out.
                          I thought you were joking about printhead in this machine, now i understand that you are serious, I'll tell you a little secret that is a laser 36" B/W plotter, laser machines have no print head. so Please do not embarrass yourself by saying you know this machine.
                          • davidj7
                            • 1107
                            I am with leo on this one . Anyone who has seen an OCE plotter knows whats he is talking about...
                            a machine is only as good as your tech : source:screwtape ; the scary one
                            • jzheld
                              • Sep 2010
                              • 162
                              Lol I'll take a picture next time I will sevice it, and I guess you and Leo will show me where is the print head there. Really want to see it. Just to be clear it's TDS 600.
