Citizen CL-S700 Label Printer shows offline through USB
  • habik
    • 2013
    Citizen CL-S700 it works thorough Parallel port but on USB side it just sits ..re-installed drivers (win7 x64) driver ver. Printer: Citizen CL-S700Port: USB001
    Product: Citizen DPL Driver
    Version: 7.3.2 M-0
    Build Target: x64
    Build Date: 1/16/2013, 11:12 AM
    Copyright (c) 1998-2013 Seagull Scientific, Inc.
    It wont print any diagnostics or reports..just does not communicate ! Any ideas?
    Firmwares HERE
  • copyguy123
    • Mar 2013
    • 10
    Re: Citizen CL-S700 Label Printer shows offline through USB
    Have you tried it on another computer?
    Does it make a sound when you plug/unplug from the computer?
    Does it have a dip switch or a menu mode that allows you to change between parallel and USB?
    • habik
      • 2013
      Thanks for the valuable info,
      I haven't got service manual for this machine and customer is not going to use it through USB so Paraller port is the only option which is now working fine after re-install of all drivers.
      Many Thanks
      habik
      Firmwares HERE
