Oki C 7530 Cyan unsynchronized
  • francoita
    • Jun 2025
    Could you help me with problem on Oki C 7530 Cyan unsynchronized on print with other color
  • Eric1968
    • 2458
    Re: Oki C 7530 Cyan unsynchronized
    If the rest of the colors are ok, then replacing the cyan drum can be an option.
    • francoita
      ThanksAre you Sure?? There aren't sensor to synchronizes the image.
      • Eric1968
        • 2458
        Every color printer uses ID-sensors to do density- and registration adjustment. In almost all Oki machines they're located under the transfer belt, and they should be kept clean to minimize adjustment errors.
        Am I sure about the cyan drum? I'm pretty sure because only cyan registration is off. But I can't take a look in your machine.
        • francoita
          Can i forced calibration in Oki printer machine???
          • Eric1968
            • 2458
            Color Menu - Density Adjustment/Registration Adjustment
