Hi,
one here for an Oce / Canon expert:
i've got an Oce CS2044 (same as a Canon machine - not sure of model) that has had a replace print heads message pop up each time I print (which is got around by pressing the online button at the start of every print.
the other day it started printing really slowly taking around half an hour to half print the final A1 page which stopped about 80% towards the end.
I had to eventually turn off the machine at the wall. Now when I power it up I get "Error E02813 Turn Power Off!" after the machine does its 5 minute startup cleaning routine.
i've done a Google search which suggests that the symptom is probably that the print head as finally reached the end of its life, but also suggests other issues:
Copiers Maryland: Error Code E02813 Canon
