Network issues
  • sniper2g8
    • Jan 2013
    • 117
    [Misc] Network issues
    Canon IR C3200. When I plug in the network cable it says check network connection. I changed the network board still the same problem what should I do.
  • HP:guy
    • Feb 2013
    • 279
    Re: Network issues
    Did you try plug that cable into your laptop to see if the connection is live?
    • sniper2g8
      • Jan 2013
      • 117
      Re: Network issues
      Yes the cable is live and it has no problem. When I connect to other machine it works.
      • DAG COPIERS & COMPUTERS
        • Oct 2010
        • 860
        Re: Network issues
        Is it a 'straight through' or cross over cable? Is the machine networked through a switch or hub? Did you set up and configure the machine properly to the network? Does the 'activity' LEDs on the NIC connection light up when you connect the Ethernet cable to the machine?
        There are many posts in the 'canon forum' about this issue; go slowly through the archives and read, to get some clues.
