Oki C5300 LED
  • blackdog
    • Jun 2012
    • 211
    Oki C5300 LED
    Hey Happy New Year!
    Got an issue with one or more of the led light bars on a c5300.
    I am pretty sure magenta is the bad boy but looking for your input on the proper way of testing each one.
    Transfer belt has 44% left to go and looks fine, as do pcu's.
    Box has 200k on it.
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: Oki C5300 LED
    LED Heads are interchangeable, so i would do a swap first to see if fault moves to a new colour...hope this helps.
    • blackdog
      • Jun 2012
      • 211
      Re: Oki C5300 LED
      Thanks, swapped out with black, printed same color pic in grayscale with same results.
      Now I'm thinking I should have printed a new all black formatted doc.?
      • JustManuals
        • Jan 2006
        • 9838
        Re: Oki C5300 LED
        Paul@justmanuals.com
        • Eric1968
          • 2458
          Re: Oki C5300 LED
          Post a scan of the image. That will make it easier to see what's wrong.
          • blackdog
            • Jun 2012
            • 211
            Re: Oki C5300 LED
            I asked customer to print a newly formatted black image and results were positive.
            This was done after I had swapped out light bars. So I am 85% sure that the magenta light bar is bad boy.
            By the way, back to my original question, is there a way of testing these light bars. Copiers have this type test simulation for their lamps etc. so I imagine there is some sort of sim.
            • Eric1968
              • 2458
              Re: Oki C5300 LED
              There's no testing procedure to test the LED-Heads. If they fail you can get Fatal Error 131,132,133,134 (KYMC), which is a communication error between the LED-Heads and the engine board.
              There are some LED-Head settings in the machine. You can access them using the Maintenance Utility. Those settings deal with correction data for each LED-Head, because each LED-Head is unique. I never used it. Replacing is easier.
              • blackdog
                • Jun 2012
                • 211
                Re: Oki C5300 LED
                Got it, and a big thanks good buddy.
