Hp clj cm4540mfp. (hard drive)
  • lilleputte
    • Jan 2013
    • 153
    Hey. I have a question regarding the hard disk of this machine. Do you have to buy hard disk from hp or you can do otherwise?. So as I understand it, they have a unique software to this disk '.
    / Lilleputte
    Thanks!
  • HP:guy
    • Feb 2013
    • 279
    Re: Hp clj cm4540mfp. (hard drive)
    If you have the hard drive here is the procedure for installing the firmware.
    1. Go to www.hp.com/go/cljcm4540mfp_firmware and follow the onscreen steps to download the
    most recent firmware upgrade files for your product.
    2. Copy the firmware update file to a portable USB flash memory storage device (thumb drive).
    3. Reinstall the formatter with the new hard drive and reconnect the power cord and network
    connection.
    4. Turn the product on.
    5. Press and hold the Stop button when all of the LEDs illuminate solid.
    6. Press the 9 button to highlight the Administrator menu, and then press the 6 button.
    7. Press the 9 button to highlight the Download menu, and then press the 6 button.
    8. Insert the portable USB storage device with the firmware update file on it.
    NOTE: If the error message No USB Thumbdrive Files Found appears on the control-panel
    display, you might need to connect the storage device to the external USB connection on the
    formatter.
    9. Press the 9 button to highlight the USB Thumbdrive menu, and then press the 6 button.
    10. Press the 9 button to highlight the firmware update file, and then press the 6 button.
    NOTE: The upgrade process can take up to 10 minutes to complete.
    TIP: If there is more than one firmware update file on the storage device, make sure that you
    select the correct file for this product.
    11. When the message Complete appears on the control-panel display, press the 5 button three
    times.
    12. When the message Continue appears on the control-panel display, press the 6 button. The product
    will initialize.
    13. When the upgrade process is complete, print a configuration page and verify that the upgrade
    firmware version was installed.
    • lilleputte
      • Jan 2013
      • 153
      connection.
      formatter.
      times.
      will initialize.
      firmware version was installed.[/QUOTE]
      I followed these steps and it worked really well. Thanks HP guy
