Okidata C8800
  • CT Copier Repair
    • Mar 2010
    • 304
    Okidata C8800
    really strange
    unit was printing a smeared menu page
    I replaced the transfer belt and it was ok
    red streaks from magenta drum unit replaced that still good ran calibration and showed eu how
    showed end user how to change toner and drum units
    I showed her on the black unit
    reinstalled black unit and smeared copy again
    reseated and it went away
    not feeling too comfortable I removed and reinstalled the black unit again
    same issue
    tried another working black unit from a printer in the other room its still smeared
    marked the drum drive gear and the drum unit gear
    power cycled gear did not appear to move
    tried it again and it moved
    Finally started getting a good menu page but the yellow is offset will not color reg
    I have the Oki C8 manual any help
    Brian
  • Eric1968
    • 2458
    Re: Okidata C8800
    Is the paper weight set correctly? Printing heavy paper with the weight settings set at normal, causes streaks/smears. Fusing Unit OK?
