Risograph error c23
  • kaiviti
    • Jul 2025
    Risograph error c23
    Hi,
    I have this model risograph CR1610 which comes up with this error C23, is there any way i could clear this error and please could someone tell where i could find the manuals for this model so i can download it.
    Thanks heaps
  • risografist
    • 18
    Users manual: http://risografist.3dn.ru/manuals/CR_User_Guide_en.pdf
    • risografist
      • 18
      C23 Master Cut Malfunction
      • If the Master positioning sensor is still detecting the master (light
      reflected back) when the Drum is at position-A after the cutting
      operation and the Master tentioning plate sensor is ON.
      • If the Master sensor detects the master on the Drum again just
      after 'C23' error is cleared, 'C23' will be displayed again.
      Resetting Method:
      Drum Set Sensor OFF & 5 seconds later ON while Master Positioning Sensor is OFF.
      • kaiviti
        malo
        thanks again for you help, i have check the loading plate and found it tobe missing a screw on the left side,everytime it goes down its hard for it to go up again then creating the error C23.
        malo aupito again
