Happy holiday...what does the 8514 error mean?
You never realize how cheap a professional is until after you let an amateur do it.... and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
thanks much appreciated...they called OCE as I was taking to long..but now I know.....how much for the resistor...do you sell
Its not a resistor, its something like a sensor for the heat. You test it by measuring its resistance using the highest range in your ohmmeter. Its should somewhere 1.3-3M ohms. If its zero or close to zero, its somewhat damage.
