Have a problem with one of these.
On first visit machine was producing magenta background all over the page but mainly in two bands down the centre.
Upon removing the photoconductor unit two lines of heavy wear were indeed present in line with the worst areas also machine was showing photoconductor near end of life.
Ordered new drum/belt unit and returned to fit today.
Machine printed two black and white pages and 1 colour page then when I tried to run the status sheet it had the magenta background all over the page again.
Removed unit and checked all connections and it appears that a slight residue of toner is present on all colour drums and the transfer belt is fully coated with what appears to be magenta and yellow toner.
Refitted the unit and got a couple of good pages then the magenta background re-appeared and the transfer belt was again fully coated.
After about 10-15 pages printed machine went into service error 103.
Re-installed old drum unit and error goes away but prints have magenta banding back obviously.
I now think there is another underlying problem as well as the worn belt so do not want to just ask for another in case it does not cure the fault
Any ideas greatly appreciated
