Oce tds-400 drum replacement
  • Polo-022
    • Sep 2007
    • 481
    A customer asked me to give him a hand...he wants to replace drum,
    but i don't know nothing about this replacement..
    Should i have to perform any adjustments or not?
    I have replaced corotrons and developer already.
    Thanks a lot for any input!!!
  • Blizzoo
    • Aug 2013
    • 594
    Re: Oce tds-400 drum replacement
    Check PM
    • vishop
      • Jan 2011
      • 220
      Replacing Drum doesn't need adjustment, replacing developer does.
      To replace drum just simply remove and put back new one.
      remove top cover
      remove front plate
      lower down the place in front of it.(forgot the name)
      on the right side, remove the drum gear and belts.
      on the left side, remove the toner hopper cover, remove toner hopper
      remove developing screws and connection on both sides.
      take out the developing
      remove drum
      to put back new drum, just reverse the process
