dell c2665dnf printer prints black
  • ldfrepairs
    • Oct 2012
    • 148
    Printer ran out of color toner so set print settings to Print black only. Received color toners and replaced. Reset settings back to color but printer will not printer in color. Check all settings in computer properties settings and in printer settings on Printer; all set to color but will print only in black. Any suggestion would be appreciated
    drugstore-onlinecatalog.com
  • subaro
    • Oct 2010
    • 1274
    Re: dell c2665dnf printer prints black
    • The output is too light
    • Toner smears or print comes off
    • Random spots/Blurred images
    • The entire output is blank
    If you are using non-Dell brand toner cartridges, enable the Non-Dell
    Toner option.
    a Launch the Tool Box, and click Service Tools on the Printer
    Maintenance tab.
    The task is complete. Go to action 3.
    b Ensure that the On check box under Non-Dell Toner is selected.
    Does this solve your problem?
    Are you using non- del toner ???, if not then go back and check if the colours are enabled. print a supplies status page, it should show the toner levels.
    Let us know. the result.
    This is a neat printer from what i see in the manual, even allowing to use aftermarket toner, and an entire pm kit by the end user. Dell is thinking above the rest for the home user. cool.
    • ldfrepairs
      • Oct 2012
      • 148
      to Subaro,
      tried your suggestion but did not solve issue
      • subaro
        • Oct 2010
        • 1274
        What else did you do ?. the user manual for this machine is 578 pages and has quite a bit of technical tools you can try. Your reply is quite dull i must say. The suggestion i gave you came all from the manual and i just copied and paste here. Your title. suggest to me you are tech
        You did not mention if you printed the status page, it must show the toner levels even in black. I saw quite a few pages the can assist you, but you have to go and search on your own. You have to learn to troubleshoot and show some zeal in your replies. Your reply is like a secretary who is just about to go home.
        IF you show some things you noticed or looked at, at what page ect, then things can go futher, but in future i would not be replying to these dead end replies.
        But in fairness, you did reply and that is the right thing. I said this, so that all who post with no-content i would not reply. ok guys don't be too hard on me now.
        ok below is from pg 254 of this manual that i downloaded from the web.
        YOU DO THIS ON YOUR OWN AND I AM NOT RESPONSIBLE FOR ANY SETTING LOST. or call dell and they may help you. or maybe someone here can help you.
        I am done with this post.
        Reset Defaults
        Purpose:
        To initialize the non-volatile (NV) memory. After executing this function and rebooting the printer, all the menu
        parameters are reset to their default values.
        Values:
        User Fax Section Initialize Initializes the fax number entries in the Address Book.
        User Scan Section Initialize Initializes the e-mail and server address entries in the Address Book.
        User Account Section Initialize Initializes the user registration information.
        System Section Initialize Initializes the system parameters.
        PG 127
        "Printer Maintenance"
        "Paper Density"
        "Adjust Transfer Belt Unit"
        "Adjust 2nd BTR"
        "Adjust Fusing Unit"
        "Auto Registration Adjustment"
        "Color Registration Adjustments"
        "Reset Defaults"
        "Initialize PrintMeter"
        "Storage"*1
        "Non-Dell Toner"
        "Adjust Altitude"
        "Clock Settings"
        "Web Link Customization"
        • subaro
          • Oct 2010
          • 1274
          Ok, i just had a coffee and back to normal. Print the status page and see what levels the toners are at. the machine must be seeing it full or will give warning or error messages. If they look at full level, remove the drum again and reinstall, pushing them firmly in.
          Is this the first time replacing the drum and toner?. If all you did was disable the colour, then there is no reason that the new toner does not work unless it is defective, yes new drum/toner can be defective, it happens.
          so when you post your rplies, hopefully it is solved and if not give some information or call dell
          • ldfrepairs
            • Oct 2012
            • 148
            Good morning Subaro,
            I follow the instructions and suggestions you posted from the manual, but even tho output is set to color it still prints black. I even reinstall over the printer drivers but no improvements.
            I printed a test sample from the Tool box and it printed all right colors but will not print color when a color print is sent from Printer
            • ldfrepairs
              • Oct 2012
              • 148
              Hey guys still have not been able to correct issue with Dell Printer.
              • ldfrepairs
                • Oct 2012
                • 148
                Just got an update from a fellow tech who was assisting with the problem. By updating firmware and resetting settings, color printing is now possible
