error code oki es5460 mfp
  • Orion2010
    • Jun 2015
    • 176
    hello all, i have Oki Es 5460 mfp and and i have this code error : Servis call, fatal error 03 and 231, please can sameone help me how to fix it?
  • EduardCj
    • Oct 2015
    • 5
    Re: error code oki es5460 mfp
    If you are lucky, could be a loose connection between print engine controller board and primary board, both located under the right side cover. Otherwise the print engine board needs replacement.
    (The print engine controller board is the smaller one, on the left)
