Panasonic DP-MB350 Doc feeder not working
  • Sharp Tech
    • Jun 2015
    • 5
    [Jamming] Panasonic DP-MB350 Doc feeder not working
    As you can see I am a Sharp guy working on a Panasonic. The guy that sold it and was the Panasonic dealer refused to look at the machine so I got lucky and he called us
    When the document is put in the document feeder there is a beep indicating the doc is set and if you go to duplex you have an option to do 2 sided originals but when you press the start button it leaves the original on the feeder. if I had something set in the feeder and press the stop button it will clear the originals. I would appreciate and direction you can give.
    Thank you
  • subaro
    • Oct 2010
    • 1273
