Panasonic UF490/4000 VoIP
  • B0265
    • Jan 2007
    • 718
    Does anyone have any experience from using UF 490 and UF 4000 on VoIP lines ?
  • tseto
    • Jun 2007
    • 60
    fax on voip lines
    using fax on a voip lines is tricky, but doable. here are a few things to make it work.
    on panafax models, turn off ECM
    V34 mode
    short protocol A and B
    do not use the fax and alarm monitoring on the same line, because the alarm uses a 25 Ma current loop to monitor line cut, this current loop can kill the fax transmission.
    ask your voip company to configure the phone adapter with a non compressing codec. , they normally use the compressing mode to conserve band width. does not work well with fax.
