The Panasonic workio DP series copier touch panel are very good until the second series and got worst on the 80 series. I got a DP-8035 with a touch panel that only works when it wants to. the problem is that I sent all used copier to recycle on the last clean up, no more 80 series for odd parts, My alternative will be: an OEM Panasonic DZTE000044R for $231.00, order a compatible touch panel from China for around $40.00 US, I have a few used DP2330 touch panel saved, does anyone know if it could be used on the DP8035. thanks for the help.
DP8035 touch panel problem
