Panasonic DP 8060
  • Zesti
    • Jun 2009
    • 308
    [Misc] Panasonic DP 8060
    I'm a Bizhub tech. Received a DP 8060 in working condition. The machine has set up with a password other than default. Any help... pl PM.
  • NIKROTAS
    • Feb 2013
    • 16
    Re: Panasonic DP 8060
    Do you mean the Maintenance password is changed? I think you must try to reload firmware.
    • birchcourt
      • May 2011
      • 20
      Try shipment set
      Verstuurd vanaf mijn SM-A310F met Tapatalk
      • ESTANISLAOWENENTON
        00000000
        • anthony palumbo
          • Mar 2013
          • 7
          i have a lower fuser pressure roller new oem if you need it for 8060 - 973-997-3999
          call me if you need help
            • 22801
            look this is three times you have posted this in the tech threads ... none of which have been related to the problem....
            if you have things for sale they should go in this forum: https://www.copytechnet.com/forums/f...ade-or-wanted/
            you also might want to review the Forum rules because I can see you aren't familiar with them: https://www.copytechnet.com/forums/misc.php?do=vsarules
