KV-S3065 Scanner
  • scanmc
    • Mar 2015
    • 183
    [Misc] KV-S3065 Scanner
    I know this is old but customer wants us to take a look at it anyway. The problem is the doc feed tray lifts up to feed the paper but as soon as it reaches the paper feed tire it goes back to the down position. I'm assuming its the optical sensor board but would rather see if anyone else has seen this issue before ordering one. Also would anyone happen to have a copy of the service utility software for testing purposes?
  • alliedofficeproducts
    • Jan 2015
    • 92
    Re: KV-S3065 Scanner
    sounds like the flat cable that is located under the paper tray. It connects to the document sensor board. This cable is flimsy and they break internally from the up and down.
    • birchcourt
      • May 2011
      • 20
      Link to software
      myQNAPcloud
      Verstuurd vanaf mijn SM-A310F met Tapatalk
