DP-265 Toner
  • ginopilotino
    • Dec 2008
    • 31
    DP-265 Toner
    I can't find black toner for my dp-265 anymore. Is there a way to use toner powder fron another panasonic printer cartridge?
    Re: DP-265 Toner
    unless you find the proper formulation, you run the risk of screwing up the machine
    • 20gaugeO/U
      • 557
      Re: DP-265 Toner
      Google Panasonic DQ-TUV28K it's out there
      • NIKROTAS
        • Feb 2013
        • 16
        Re: DP-265 Toner
        Ask Alexa!
        • xring1958
          • Mar 2016
          • 166
          Re: DP-265 Toner
          Once upon a time we could get bulk toner to refill color panasonic machines but I dont think black was available.
          Panasonic went to great trouble to make sure their color machines couldn't share toner ctgs so they had serieses of toner tubes
          they end in letters like N S V & W we have often taken toner from another series of toner tube and transferred it to the one we needed
          you will need to undo the tape on the tube where green top is and remove top. I usually tape empty tube to top of full on opening to opening and flip over. Be carefull. I dont think other panasonic toners will work.
          Good luck.
