Panasonic 7835 code U-14
  • KHAN
    • Aug 2006
    • 261
    Hello friends I never work on any Panasonic copier, now i have FP 7835 which shows code U-14 wast toner?
    How to reset ? please need help
    THANKS.
  • The-Peanut
    • Aug 2006
    • 192
    U14 cannot be reset, u replace the waste container
    if u empty the waste container check the overflow lip, the sensor looks through that to see if the waste container is full
    • KHAN
      • Aug 2006
      • 261
      ok thanks i will chick this.
      Thanks for your help.
      • The-Peanut
        • Aug 2006
        • 192
        No probs
        anything with a U code is a user's problem, anything with E code is a engineering problem
        the user should be able to replace the waste container themselves, usually when u supply a toner u get a waste container also
