8016 memory full
  • Magebomba
    • Dec 2008
    • 92
    8016 memory full
    anyone ever have the dp-8016, only through the docfeeder, show a memory full after attempt to copy?
  • The-Peanut
    • Aug 2006
    • 192
    if i remember rightly the machine only comes with 16mb memory as standard so if the items your scanning to copy are heavy in text its possible that the memory becomes full
    i've never had it while copying i suppose it could happen if the copier is scanning the documents quicker than its printing them
    i have had it while its scanning to PC
    the memory is upgradeable to 144mb
    hope that helps
    Peanut
    • Magebomba
      • Dec 2008
      • 92
      ya im thinking sc board its too weird, thanks alot for the response peanut
      • etsmultan
        • Apr 2007
        • 131
        Clear the ram,copier will work
        • higherlevel
          • Aug 2006
          • 30
          For the Panasonic DP-8016/DP-8020 series, Panasonic sent out some machines with a crack on the SC PWB, Memory full when using ADF,
          is the system, I had one with the same problem out of the box.
