DP-8060 Bending Upper Fuser Claw Support
  • mojorolla
    The Wolf
    • 2588
    The retrofit from Panasonic gives the following part #:PJZSF2758PU
    • Waylon
      • Sep 2010
      • 26
      I would like to add another factor that promotes fuser jamming, that is FC webs that are too dry. web should be moist but not dripping with fuser silicon oil. if it is not I add some to the web. any brand will work. Most of the webs i see are too dry out of the package and will only get worse, expecially if it is a low volume machine. Dry webs promote static build up.
      As for toner density I like to use F6-21 to manually manipulate it. a more negative # will give you less toner in the developer unit but I also usually turn off the quantum in F5-25 if it has come to manual manipulation to get the machine to run smoothly.
