panasonic 1520
  • blsquires
    • Nov 2008
    • 342
    panasonic 1520
    bypass will not feed ,i have replaced the feed clutch ,gear,solonoid and feed roller but the feed is still intermitant .the bypass lifts up ready to feed then drops again before the paper is fed .
    any help apreciated
    thanks brian
  • blsquires
    • Nov 2008
    • 342
    thanks for all the help
    as it says in the title
    • The-Peanut
      • Aug 2006
      • 192
      any help apreciated
      thanks brian
      lo m8, the plate that holds the paper against the bypass roller can sometimes bend at the joining point of the clutch, thus the paper is not pressured against the roller enough, just bend it back
      there is a T.I for the bypass, they modifed the bypass roller and added a washer. lmk if u need it
      John
      • blsquires
        • Nov 2008
        • 342
        panasonic 1520
        thanks for the reply i tried the metal plate but no go .i even went and borrowed the whole bypass unit from another machine and still no go .i have now ordered a new main board .i will post if it fixes the machine.
        thanks again brian
        • blsquires
          • Nov 2008
          • 342
          panasonic 1520
          just to let you know the paper feed problem from the bypass was a faulty brand new (according to panasonic) rego clutch it was working but obviously not properly .any way machine fixed and gone back.
          brian
          • The-Peanut
            • Aug 2006
            • 192
            brian
            so it was just the solonoid that sits at the back of the machine?
            • blsquires
              • Nov 2008
              • 342
              no it was the rego clutch
              • MPM2140
                • Mar 2010
                • 13
                Can you please tell me the part number for this clutch....
