E03-10 Error
+ More Options
Posts
  • ansuman
    • Oct 2008
    • 14
    E03-10 Error
    I hav a Panasonic DP-8016 machine but recently the machine is showing E03-10 code. I hav changed Corona wire still i am nt able to detect the problem. Plz help
  • Mad_Coachman
    • 99
    E03-10 FIX
    The Drum unit is losing ground.Remove the flywheels and loop a paper clip around the driveshaft.Make sure to tuck the other end of paper clip into a slot on the frame.There is a bulletin about this on the Pansonic B2B website with an official mod but my fix accomplishes the same thing!
    • ansuman
      • Oct 2008
      • 14
      E03-10 Code
      Thanks for the reply but i m not able to explore the site b2b.panasonic.com,plz help and guide how to registrr in the site
      • Mad_Coachman
        • 99
        E03-10 FIX
        Just try the fix.it works
        • The-Peanut
          • Aug 2006
          • 192
          Find the T.I attached
          John
          • ansuman
            • Oct 2008
            • 14
            Thank John. I hav taken a printout and i will try according to the instructions. If any Problems arises i will mail you. Thanks also Madman but still I m nt able to log in the site.
            Ansuman
            Assam, India,
            suman311281@yahoo.com
            • ansuman
              • Oct 2008
              • 14
              Ansuman
              Assam, India,
              The machine is showing E03-10, Check Printer
              • Vista Tech
                • 116
                If your still having this problem try changing out the corona unit. I've seen corona units ground out in the past and throw out this code.
