Feed Tires
  • ToshibaTech
    • Apr 2007
    • 580
    Feed Tires
    Just wondering about something. I used to work on Panasonics and still know some guys that do. They were saying they go through feed tires like water and I remember always carrying a bunch. Anyone else seeing this especially flat spotting the sep tire?
    I remember the hubs always squeaking on the P/U and Sep. and you could swap them (hubs) and it would quit for a while and I remember them going out like crazy. Mostly on the 3510(?) and 2500 series size machines. The ones with the Sep/Pickup being the same and the feed being different. Changed out with a clip on the hub.
    Anyone? Any advice?
    I will not give you service manuals or firmware.
  • The-Peanut
    • Aug 2006
    • 192
    Anyone? Any advice?
    Hi m8
    the dp2500 series and dp2310 series have the same tyres, the dp3510 series have different tyres
    going back to the 2310 tyres, 2 of them r the same and can be swopped if not to badly worn, the flat spot is caused by a spring inside 1 of the 2 tyres. remove the spring and spray wd40 over it then wipe it dry, refit the spring and that should do.
    hope that jogs your memory,
    Regards
    John
    • yakyitz
      • 243
      Feed Tires Panasonic
      Ever since they came out with new rollers (black to easily spot the difference ) I've had very few problems Pn# dzla000407 for the dp-2500 machines. If you are talking about the 35/45/6010 series they came out with an update as well, changed the roller,gears and spring
      • ToshibaTech
        • Apr 2007
        • 580
        Yeah that advice probably helps. The place where I still know some guys who work on them don't use those updated parts I am pretty sure, or at least did not when i was there. I'll pass it along though.
        Thanks!
