DP C262 E326 error
  • deputydogg
    • Nov 2015
    • 172
    DP C262 E326 error
    Machine displaying E326, customer says they replaced all drums and still getting message. I'm not too familiar with Panasonic so just trying to get a heads up before I go out. Any suggestions ?
    Thanks,
    Dave
  • mojorolla
    The Wolf
    • 2627
    Re: DP C262 E326 error
    Color drum rotation error. It is a general code indicated one of the 3 color drums. You can remove drums and turn by hand to determine which is binding up. I have seen a few new drums that wouldn't sit right on the rear frame. You had to remove them from the machine and turn the drive gear until you heard an audible click.
    Also, people love to confuse the toner and drum units on this model. The verbiage on the screen is not the greatest...
    • deputydogg
      • Nov 2015
      • 172
      • richs
        • Nov 2008
        • 264
        Wow....where is the customer getting new drums from?
        • deputydogg
          • Nov 2015
          • 172
          I'm not sure but they are not OEM.
          Thanks,
          Dave
          • mojorolla
            The Wolf
            • 2627
            I would suspect the non OEM drums are causing the issue. If you have the originals drum, re-install them and there is a drum reset in service mode.
            I remember it exists but I do not remember where it is in service mode. Been over a decade since I touched one of those.....
            • deputydogg
              • Nov 2015
              • 172
              I put the drums back in that were in it originally but they are not OEM either. I'm not sure its worth it to buy OEM drums, if they are still available.
              Do you remember if there was a code to run the drums in service mode ?
              • Logged-on
                • Sep 2010
                • 197
                Seems I remember there is a flag on the back, maybe on the front? of the drum sometimes in transport the flag gets tripped, simply snap the flag back to home position until it clicks, and slide the drum back in.
                Good luck.
