DP-2500 Panasonic
  • MR. COPY
    • Aug 2025
    DP-2500 Panasonic
    How difficult is it to change a complete fuser assembly and reset the code E-04-01 on a DP-2500 Panasonic. Is it expensive for the fuser unit.
  • vedder
    • 131
    2500 fuser are pretty tricky, the hardest part is getting them out, then back in again, the screw at the back under the thick wire loom is a pain!! For E4-01 I would try a lpb fuser reset before anything else, cheapest option, I have reset E4-01 errors before and have had no problems after.
    • MR. COPY
      DP-2500 fuser
      I thank you very much for the response. I have not worked on the DP-2500 before and it looked complicated. The fuser rollers are both in bad shape. The unit is very expensive also. I will try and reset it and see if that gets it going. Will have to talk with him about another copier.
      Thanks again:
