I had to replace my wireless modem, now I can't print from my computer to the copier. What do I need to do so that the copier picks up the wireless communication?
Panasonic dp-c405 new modem
Make sure that you have the IP Address and subnet mask for your new router plugged into your copier. All the numbers need to match up. These machines are supposed to run on a static IP so when you put in the new router it could have altered something.
Also make sure that the Ethernet Cable is plugged in. These machines didn't come standard with a wireless card.Last edited by Vista Tech; 03-16-2009, 06:08 PM. -
derek
make sure you have dhcp turn to no on the copier or the compter will change the ip address on the copierComment
to change the ip address you go through general settings and key operator mode, (Page 6)
make sure dghp is off if u manually change the ip address, however u will need to change the ip address on your computer to match up with the copierComment
It's possible with getting a new router that your gateway address changed. As an example, If you had your copier set to something like this: Gateway: 192.168.1.1, IP: 192.168.1.7. and your gateway changed to 192.168.0.1, It doesn't know where to send the information now. So the gateway would have to be changed to 192.168.0.1 and IP would need to be changed to 192.168.0.7. Also, the port would have to be changed at each computer who prints to it to reflect the new ip address.Comment
