Panasonic KV-S5078Y document scanner parts?
  • Przemek
    • Jan 2023
    • 2
    Hello, we have Panasonic KV-S5078Y with scratched glass/plastic which unfortunately shows on scanned images. Since apparently panasonic discontinued this model I have a hard time finding parts. Does anyone know where I can find parts like PNHR2625 and PNHR2626? I would be grateful for any tip thanks.
  • subaro
    • Oct 2010
    • 1274
    Re: Panasonic KV-S5078Y document scanner parts?
    This is why we have all the waste and pollution. These are nice high speed scanners and can work for a long time with just the normal feed rollers and regular cleaning. The glass I can see can get damage when stapels ect, go through them.
    But I thind you are screwed and now eithier you find a way to replace the glass or it goes to the junk heap or parts machine. It is still an expensive machine.
    You can take out the part, remove the glass and go to a glass cutter and have him fit a replacement glass to match. Then use double sided tape to fix it in place.
    Oh, I now see , the glass has a conductive coating to prevent static. You can buy that stuff and coat the glass.
    • Przemek
      • Jan 2023
      • 2
      This is a fantastic machine. Unfortunately we are using it wrong. This is made for legal documents so 20lbs legal/copy paper that is clean. I am forced to use it on near 90-100lbs paper that is often 200 years old. One job alone destroyed my plastics. They are all covered in microscratches which would be ok if i didnt have to scan in grayscale mode which picks up EVERYTHING. I had a call with panasonic technician and apparently they have the whole assembly for sale which we will probably buy. i will probably try your idea too since i feel these can be saved
      • adunz
        • Feb 2014
        • 2
        You can get Panasonic parts from these folks:
        Panasonic Connect
        1615 Dundee Ave. Dock G.
        Elgin, IL 60120
        847-888-7000
        Panasonic Parts and Accessories
        • abusivemallet
          • Dec 2024
          • 1
          geometry dash free
          Panasonic Connect
          Elgin, IL 60120
          847-888-7000
          Can I buy online?
