Panasonic FP 7818
  • Wheedoggi
    • Sep 2025
    Panasonic FP 7818
    I have a Pan 7818 where the waste toner builds up in a pile in the middle of the drum unit behing the cleaning blade. The coil is turning and dumping some waste into the waste bottle. I vac it out and everything is OK then it happens again after a few weeks. I have seen this problem in the past and can't remember if Pan resolved it.
  • Utahrob1
    • 38
    They did resolve it with mylars that would clean the auger. Or knock the toner off the auger that is, so the toner wont build up on the auger. I have no idea if they still sell that mylar or even the part number. But i am sure that is something you can make yourself if need be.
    Good luck Robert
    • Wheedoggi
      Toner
      Cheers Rob, It has the mod fitted.
      • onetek
        • 318
        It does that when the middle of the mylar come unglued (even slightly)....Panasonic calls this part "loop mylar" pn# FFPHK1068B. Th.
        • Wheedoggi
          Thanks for the tip. I'll check that on my next visit.
          • Garren Northrop
            you need a toner support its a strip of plastic that peels off and you put a new one on it i also know that its could be heat thats causeing your prob take out the fan filters and this helps
            • Wheedoggi
              Hi Garren, thanks for the info. The support strip is OK I checked it, but the heat could be a problem, Small office with quite a bit of kit in there running all day.
              • Greg2003
                Garren is right on about the heat. Years back, we had about 10 machines doing this 18cpm - 50cpm. Remove the exhaust filters above the fuser.
                Greg
                • Wheedoggi
                  Many thanks for your help.
