I have this fax not feeding from copy tray. All gears spin but solenoid does not fire. Anyone ever have bad noid or another item may be causing this? Need solenoid part # if you can give it. Good parts supplier? Thanks
you need to replace a paper feed clucth part # DZKN000073 Spring is bad its location in the right side of machinelift up the adf front remove side cover 3 silver screws it behind the one screw on wire remove the metal piece its house in white plastic witha black top side off the shaft after removing the pink clip. the spring will be bent in the middle you need to replace for paper to feed.
