I have a customer printing a 90 page PDF and it is takin 30 minutes, Any thoughts?
Panasonic DP-8060 Slow print with PDF
Sounds like a print spooler issue with their server. But if they don't have the PDF post script drivers I would recommend loading those. -
Spoiler1
Thank you for the suggestion, I found that using the GDI driver verses the PCL driver reduced the print time went from 15 minutes to 2 minutes.Comment
DP8060 slow printing
If you load the PCL driver don't you need the PCL chip for it to work or it will print without the PCL chip???Comment
Panasonic recommends using GDI drivers. Even generic will help increase speed....specially if you have a Vista machine sending the print job!Comment
Spoiler1
Slow PDF printing
Using the GDI driver was the answer, it is printing at almost rated speed versus panfully slow.Comment
