Resetting the counters on Panasonics are all the same process. Go to F5 and change the PM count to 240k, if its already at 240k just highlight a different number and then put it back to 240. Go to F7 and reset the fuser web counter and OPC drum counter. That should be all you need to do.
Hello everybody! I have the "wrench" (service) light on. Any idea how to reset it? I suppose it has to do with the counter but when i enter my key operator id (000) i do not find a "reset counter" or "reset service" feature. Any guidence will be realy apreaceated.
P.S. if there is a service manual out there I would be more than greatfull if some were to share it with me.
The DP-1510 is an older generation machine that does not have fuser web.
you might have a fuser error.
Does the screen show any error code? or does the machine work at all?
