panasonic dp 190
  • patrickj420
    panasonic dp 190
    prints good, but when you make a copy the pages come out solid black.i changed the ccd module assy with no changes. any idea what this problem could be and if you have a part number.
  • onetek
    • 318
    Replace scanner home position sensor...
    • scepter2112
      • May 2009
      • 72
      I had this problem a few years ago and it turned out to be a ground problem on scanner/ccd unit.They Modified it, where did you get your replacement?
      • patrickj420
        precision roller
        • onetek
          • 318
          see any error codes in f9-print device info-machine info ????
          • Vista Tech
            • 116
            Try taking the scanner unit apart, on the rail you will notice its lubed but the lube gets sticky. I had this problem a few months back. Take the rail completely out and clean it with belt cleaner or rubbing alcohol, also make sure you clean out the brackets that the fits into on the scanner unit. Relube the assym with a bit of TriFlo and you will not have the problem anymore.
            Hope this helps
            Tom
