DP8060 jams
  • m.verucchi
    mtech
    • 18
    DP8060 jams
    We have DP8060 giving us J50 J40 and J41 jams. We have replaced the fuser exit sensor and all inverter sensors. Any help will be appreciated
  • Vista Tech
    • 116
    Did you check the mylar in the inverter? Some times those guides get a little bent and its very in conspicuous.
    • serviceman
      • Jun 2009
      • 71
      There is a door underneath the fuser unit door. Open that, take out the feeder assy in there, eithe 2 screws each side or 4 screws each side and then it just pulls out. There are 2 springs that wrap around 2 roller shafts to keep tension on them. Check to make sure they aren't broke. It's a long shot, but it bit me in the butt one time.
      • onetek
        • 318
        New fuser upgrade kit pn#PJZSF2758PU needs to be ordered....
