DP-150FX
  • Yvan in Welland
    • Jun 2025
    DP-150FX
    Afer replacing the Drum Unit on a Panasonic DP-150FX Copier, I still get the message "Replace Drum Unit" and cannot make copies.
    Is there something that must be reset to clear this message and allow copying? If so how do I do it?
    Thanks in advance for your help.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    paul@justmanuals.com
    • onetek
      • 318
      You dont need a manual for that one. Just get to f7,(press photo/auto+paper tray+1),reset f7-04 to 0. Then press photo/auto+clear to get out of f mode.
      • Yvan in Welland
        Thank you both for the information, I will download the Service Manual for future needs.
        Onetek, I was able to enter the F7 area and access the F7-04 counter which is at 29630. However after trying different keys, I was unable to reset the counter to 0. Can you please identify for me which keys I need to press to zero-out this counter.
        • safos
          • Dec 2007
          • 13
          try f7-c04 start 0 start and then exit .
          • Yvan in Welland
            Thanks a million Safos ! ! !
            I was able to reset the C04 drum count to "0".
            I can now make copies but they are extremely light even with the Auto/Photo select key in the "Auto" mode.
            How can I make them darker? I presume some adjustments are necessary in F6 (Adjustment and programming), but which code? ? ?
            Can someone please help me out with this one as well.
            Thanks in advance for your help. It is much appreciated.
            • safos
              • Dec 2007
              • 13
              • onetek
                • 318
                If copies are light, make sure your mag roller is clean, and that your transfer roller springs are ok. Then you can increase f6-19 to darken prints. before that, make a copie of your f5-f6 settings by going to f9, then 2, then start.
                • Yvan in Welland
                  Thanks Safos,
                  Pardon my ignorance, but how do you indicate a plus (+) or minus (-) sign when entering the value with the keypad to indicate that the value entered in C50 or C51 is a (+) or a (-) value ? ? ?
                  Thanks again for your professional advice.
                  Yvan
                  • safos
                    • Dec 2007
                    • 13
                    Enter the adjustment value.
                    Press Start key.
