Some kind of bypass code. I can use bypass when selected but if switch to front casette the e2-01 code flashes. As soon as I select bypass e2-01 disappears and bypass is ready to feed. There was a little straw in bypaas which I had removed and all looks okay. Frank/ActionPhotocopy
Panasonic 7718 has e2-01 code
Well Marc ---I owe you a double thank you. Even though you had already given me the pertinent and timely info I always feel that is appropriate to thank those who offer to help . i also try to always give results when job is done.
it would be very shallow of me not to thank Luong Nam for his input and at the same time time take some credit for having learned valuable info from you. Thanks again Marc(That's 3 times and 4 if you count Smarka. FrankConcerto/ActionPhotocopy On Facebook and I only have like 11 friends ,mostly family.Comment
